CUBE is it possible to translate based on called and calling number ?
tristan
is it possible to translate a number based on calling and called number
if a cli comes in with a leading 0 & has a destination starting  44 ,remove the 0 & add +44 in front of the CLI.
tristan
i suppose this has to be done by matching a dial-peer incoming called number then translating, just seems alot
of administartive work, and a lot of dial peers...
tristan@voipsolutions.co.uk
It is, and for that reason it may be  much more effective to use a custom TCL/IVR script for advanced number maniputation.
has anyone got any examples ?
UK            if a cli comes in with a leading 0 & has a destination starting  44 ,remove the 0 & add +44 in front of the CLI.
FRANCE   if a cli comes in with a leading 0 & has a destination starting 33 ,remove the 0 & add +33 in front of the CLI.
Germany   if a cli comes in with a leading 0 & has a destination starting 49 ,remove the 0 & add +49 in front of the CLI.
My script "number to name" can do something like that.
It can be acquired on the website present in my profile.
