CUBE logging of voice calls
goranpilat
Level 3
Level 3
I have a setup where Cisco CUBE is the central point to all the voice subsystems, and as such, perfect place to gather the list of all successfull calls that went towards PSTN behinf SIP trunk.
Does anybody have such experience, how to log/export all the calls with minimum of details (DNIS, ANI, length, time when started), for example every hour or so
Any suggestion is appreciated
Goran
Hi, you can export the CDR using syslog or radius.
You must enable voice call logging using the command 'gw-accounting syslog'.
Test it with 'terminal monitor' from the console.
Regards.
