CUBE Media Forking Dial Peer Question
kevbo
Contributor
Contributor
Morning all
Could someone please assist with the query below?
I am setting up CUBE media forking for call recording.
I have configured the following and it works fine.
#dial-peer hunt 0
#media profile recorder 100
#media-recording 1111
#media class 100
#recorder profile 100
#dial-peer voice 1111 voip
description SIP Trunk to the recorder for CUBE recording
destination-pattern 1111
session protocol sipv2
session target ipv4:<IP ADDRESS>:5060
session transport tcp
#dial-peer voice 5 voip
description *** Match Inbound from CUCM ***
incoming called-number .
voice-class codec 100
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
media-class 100
dtmf-relay rtp-nte
no vad
However we are setting this up so we can record specific exts outbound to the PSTN (trying to record third party SIP devices that have no BIB)
I set up a test dial peer to capture a specific ext e.g. 411483 for recording but it does not work. It still hits the less specific dial peer 5
#dial-peer voice 1112 voip
incoming called-number 411483
media-class 100
dtmf-relay rtp-nte
no vad
 CUBE#sh call act voice brief | i pid
<ID>: <CallID> <start>ms.<index> (<start>) +<connect> pid:<peer_id> <dir> <addr> <state>
10   : 15578371 837864988ms.1 (16:58:33.939 GMT Wed Nov 22 2017) +12510 pid:5 Answer 411483 active
10   : 15578372 837864998ms.1 (16:58:33.949 GMT Wed Nov 22 2017) +12500 pid:9 Originate <MOBILE NUMBER> active
I tested media forking with outbound dial peer and it worked fine..
#dial-peer voice 11 voip
description *** CUBE to SBC1 ***
translation-profile outgoing SIP-OUTBOUND
destination-pattern 9<MOBILE NUMBER>
session target ipv4:62.239.36.229
voice-class sip profiles 100
voice-class sip options-keepalive
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
media-class 100
dtmf-relay rtp-nte
no vad
10   : 14890647 325644178ms.1 (18:41:33.136 GMT Thu Nov 16 2017) +4380 pid:5 Answer 411293 active
10   : 14890648 325644178ms.2 (18:41:33.136 GMT Thu Nov 16 2017) +4380 pid:11 Originate <MOBILE NUMBER> active
10   : 14890654 325648568ms.1 (18:41:37.526 GMT Thu Nov 16 2017) +50 pid:1111 Originate 1111 active
Any help on this much appreciated.
Cisco IOS XE Software, Version 03.16.04a.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4a, RELEASE SOFTWARE (fc1)
Jonathan Unger
Rising star
Rising star
Hi There,
If you are trying to match the inbound dial-peer based on the calling extension you will need to use the "answer-address <EXT>" command instead of incoming-called number. You will also need to change the way that your dial-peer voice 5 is configured since incoming-called number always takes precedence over answer-address.
If it works for your environment you could remove "incoming called-number ." from peer 5 and insert more of a catch-all pattern in there like "answer-address 4.....". That way all calls which are not caught by your more specific VOIP dial peer 112 (which has forking enabled) will be caught by your generic "non-forking" dial-peer 5.
Have a look at this document, it goes over how incoming and outgoing dial-peers are matched.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html#topic3
Hope this helps!
- Jon
Jonathan Unger
Rising star
Rising star
Hi There,
Hope this helps!
- Jon
Hi Jon
I did try answer-address but missed the fundamental point that incoming-called is serviced first! I will give your solution a try.
Thanks for taking the time to respond, much appreciated.
Kev
Thanks for the helpful vote, let us know if this ends up working for you!
- Jon
Just to add to Jonathan's post, be aware of the following:
Incoming called-number. Takes preference over any specifically matched incoming called-number.. This is why you are seeing this behavior. I will suggest you remove incoming called-number.  And replace with a more specific match for your dial peers. This way you can configure specific inbound dial peer using incoming called-number
Please rate all useful posts
Recognize Your Peers
