CUBE on 4431 with PVDM4 in NMM slot
ranjithgs
Hi All,
Does CUBE use DSP resources of PVDM4 in NIM slot, after it runs out of credit for transcoding from the PVDM4 in ISC slot of motherboard?
URL
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-728307.html
says "A PVDM4 module plugged into the T1/E1 NIM would be used for voice T1/E1 connectivity. Any excess channels can be reused toward other IP-based services supported on the motherboard slot"
while
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/qa_c67-728261.html
says "You can insert PVDMs on both the motherboard and directly on some NIMs, depending on the use case. CUBE requires that PVDMs be installed on the motherboard, whereas time-division multiplexing (TDM) deployments require them to be installed directly on the NIM."
Chris Deren
Basically if you have TDM circuits i.e. PRI they can only use PVMDs from the NIM where the card is installed. DSP services such as conferencing, transcoding can use PVDMs from the motherboard and from any NIM cards.
Chris Deren
