IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5405 Views
  • 14 replies
Hi!I have an issue with my cucm 10.5.I have a sip trunk that is connected to the telephone service provider, and when someone calls to another user of the same cucm, but dialing the long number (the number providade by the telephone service provider ...
mamaral by Level 1
  • 295 Views
  • 1 replies
We are facing issue with Cisco IP Phone 7821 model.... CME 10.5 version we are using ..IP Phone is not registering ...when we go to the setting its ask us for credentials to check the settings ..where we are trying to check IP address parameters. one...
Im using a SIP provider (voip.ms) to a H323 gateway (2801) and from there go to my CUCM 8.6 server.  Inbound calls work fine, i get ringback and outbound calls connect and work fine, i just hear no ringback on my outbound calls via my SIP provider.At...
JZegers06 by Level 4
  • 20208 Views
  • 27 replies
I need to go on a VMWare course , Though I configure CUCM , UCCX, UCCE , Installs on MCS, Upgrades, ES etc. I have little experience from a Virtual  point of view. I’ve seen various courses but not sure of the one to take - I`m not after the full cou...
iptuser55 by Level 6
  • 183 Views
  • 1 replies
Hi, Please consider following configuration: dial-peer voice 1 voip incoming called-number . dial-peer voice 2 voip incoming called-number . session protocol sipv2 Looking into documentation I did not find anywhere dial-peer protocol to be used for...
