Does anyone know if CUBE is supported in SD-WAN? Everything I find references SIP-to-Analog only and some 2020 document saying other functionality is on the roadmap. Is it actually possible to configure SIP-to-SIP dial-peers, where:
1. CUCM is in VPN 1 and SBC is in VPN 0
2. CUCM is in VPN 1 and SBC is in VPN 1
I know this is possible in autonomous mode as dial-peers are vrf-enabled, but what about SD-WAN?
Thank you!
