CUBE question
Dmitry Blinov
I kindly ask to advice the best way to configure the following chheme at the CUBE (SIP):
cucm1pub (10.0.0.1) ----|
                        |---- (10.0.0.3) cube (192.168.0.2) ------ (192.168.0.1) ITSP
cucm2sub (10.0.0.2) ----|
The goal is:
- all calls incoming from cucm1pub and/or from cucm2sub should go to the ITSP
- all calls incoming from ITSP should go to the active cucm (publisher or subscriber)
- monitor of availability of the link (192.168.0.2) ------ (192.168.0.1) so cucm be able to know if the link is faulty and chooses an alternate route
Is it possible to make matching in dial-peers on the source IP instead of the destination pattern? I guess this could simplify of the config.
Dmitry
Jaime Valencia
There are plenty of docs on CCO on CUBE config, as well as plenty of examples on other CSC threads, have you reviewed them????
and no, you match a DP on destination pattern, I'd suggest you review some dial peer configuration guides to understand how they work
java
if this helps, please rate
Jaime Valencia
java
The valuable of your answer is that you gave me right direction. I couldn't believe solution is so simple - I got it working properly.
