07-19-2023 09:45 AM
I am setting up the Soalrwinds VNQM module to monitor the Sip trunk status of Cube using SNMP. I enabled the keepalive on the dial-peers and see the trunk status "up" for some sip trunks and "unknown" for other dial-peers in SolarWinds. The sample configuration (Removed some unwanted lines here) below,
dial-peer voice 300 voip
description inbound from CUBE to CUCM
session target ipv4:10.114.1.28
voice-class sip options-keepalive up-interval 100 down-interval 50 retry 6
The sip trunk status is active for dial-peer 300
dial-peer voice 311 voip
description outbound from CUBE to Omega
destination-pattern .T
session protocol sipv2
voice-class sip tenant 311
session target dns:sip1.cy2.omega-telecom.net:5744
voice-class sip options-keepalive profile 311
voice class sip-options-keepalive 311
description keepalive Omega Trunk
up-interval 5
transport tcp
sip-profiles 311
Sip trunk status is unknown for 311. The 311 dial-peer is connecting to PSTN which is a sip circuit having credentials-based authentication. Any additional configuration requires, or do we need to monitor the sip-ua status for credentials-based sip authentication circuits?
Please advise.
Diji
07-20-2023 01:32 AM
You should not need to do anything special for SIP option ping to work with authentication based SIP connections. Here is an example of a configuration we have for one of our sites and it shows the dial-peer in active state.
voice class sip-profiles 10
request INVITE sip-header SIP-Req-URI modify "<redacted> " "spark.co.nz"
request ANY sip-header From modify "10.154.4.10" "10.154.11.189"
request ANY sip-header From modify "From:(.*)(<sip:)\+(.*@).*>" "From: \2\3spark.co.nz>"
response ANY sip-header From modify "From:(.*)(<sip:)\+(.*@).*>" "From: \2\3spark.co.nz>"
request ANY sip-header From modify "From:(.*)(<sip:.*@).*>" "From: \2spark.co.nz>"
response ANY sip-header From modify "From:(.*)(<sip:.*@).*>" "From: \2spark.co.nz>"
request INVITE sip-header To modify "To:(.*)(<sip:.*@).*>" "To: \2spark.co.nz>"
request ANY sip-header To modify "To:(.*)(<sip:.*@).*>" "To: \2spark.co.nz>"
response ANY sip-header To modify "To:(.*)(<sip:.*@).*>" "To: \2spark.co.nz>"
request ANY sip-header Contact modify "Contact:(.*)(<sip:)\+(.*@.*>)" "Contact: \2\3"
response ANY sip-header Contact modify "Contact:(.*)(<sip:)\+(.*@.*>)" "Contact: \2\3"
request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*@.*>" "P-Asserted-Identity: \<redacted>@spark.co.nz>"
response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*@.*>" "P-Asserted-Identity: \<redacted>@spark.co.nz>"
voice class sip-options-keepalive 2000
description Used for Service Provider SIP OPTIONS PING
voice class server-group 2000
ipv4 <redacted> preference 1
ipv4 <redacted> preference 2
voice class tenant 2000
registrar dns:spark.co.nz expires 3600
credentials username <redacted> password 7 <redacted> realm spark.co.nz
authentication username <redacted> password 7 <redacted>
no remote-party-id
timers dns registrar-cache 95
sip-server dns:spark.co.nz
connection-reuse
audio forced
bind control source-interface GigabitEthernet0/0/1
bind media source-interface GigabitEthernet0/0/1
no pass-thru content custom-sdp
sip-profiles 10
outbound-proxy dns:gvc-tg0102.spark.co.nz reuse
early-offer forced
dial-peer voice 110 voip
description Outbound calls to PSTN
translation-profile outgoing PSTN-OUT
session server-group 2000
destination e164-pattern-map 2000
voice-class codec 10
voice-class sip tenant 2000
voice-class sip options-keepalive profile 2000
dtmf-relay rtp-nte
no vad
Status of dial peers
nzaurt-cube-01#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS SESS-SER-GRP\ OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF
1000 voip up up 0 syst NA
1010 voip up up map:1 0 syst SESS-SVR-GRP: 1 active NA
100 voip up up 0 syst NA
110 voip up up map:2000 0 syst SESS-SVR-GRP: 2000 active NA
07-20-2023
01:52 AM
- last edited on
07-20-2023
02:25 AM
by
rupeshah
HI Roger,
It looks like i have similar configuration. Do you see any issue on the below config?.
voice class sip-profiles 311
rule 10 response ANY sip-header From modify "10.250.57.33" "192.111.84.36"
rule 11 response ANY sip-header Via modify "10.250.57.33" "192.111.84.36"
rule 20 response ANY sdp-header Audio-Attribute modify "a=candidate:1 1(.*) 10.250.57.33 (.*)" "a=candidate:1 1\1 192.111.84.36 \2"
rule 30 response ANY sdp-header Audio-Attribute modify "a=candidate:1 2(.*) 10.250.57.33 (.*)" "a=candidate:1 2\1 192.111.84.36 \2"
rule 40 response ANY sdp-header Audio-Connection-Info modify "IN IP4 10.250.57.33" "IN IP4 192.111.84.36"
rule 41 request ANY sdp-header Audio-Connection-Info modify "IN IP4 10.250.57.33" "IN IP4 192.111.84.36"
rule 50 request ANY sdp-header Connection-Info modify "IN IP4 10.250.57.33" "IN IP4 192.111.84.36"
rule 51 response ANY sdp-header Connection-Info modify "IN IP4 10.250.57.33" "IN IP4 192.111.84.36"
rule 60 response ANY sdp-header Session-Owner modify "(.*) IN IP4 10.250.57.33" "\1 IN IP4 192.111.84.36"
rule 61 request ANY sdp-header Session-Owner modify "(.*) IN IP4 10.250.57.33" "\1 IN IP4 192.111.84.36"
rule 80 request ANY sdp-header Audio-Attribute modify "a=rtcp:(.*) IN IP4 10.250.57.33" "a=rtcp:\1 IN IP4 192.111.84.36"
rule 81 response ANY sdp-header Audio-Attribute modify "a=rtcp:(.*) IN IP4 10.250.57.33" "a=rtcp:\1 IN IP4 192.111.84.36"
rule 91 request ANY sdp-header Audio-Attribute modify "a=candidate:1 1(.*) 10.250.57.33 (.*)" "a=candidate:1 1\1 192.111.84.36 \2"
rule 93 request ANY sdp-header Audio-Attribute modify "a=candidate:1 2(.*) 10.250.57.33 (.*)" "a=candidate:1 2\1 192.111.84.36 \2"
up-interval 5
transport tcp
sip-profiles 311
voice class tenant 311
registrar dns:sip1.cy2.omega-telecom.net:5744 expires 600
credentials username xxx password xxx realm sip1.cy2.omega-telecom.net
authentication username xxx password xxx realm sip1.cy2.omega-telecom.net
retry invite 2
retry register 5
sip-server dns:sip1.cy2.omega-telecom.net:5744
connection-reuse
host-registrar
session transport udp
header-passing
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
pass-thru content sdp
outbound-proxy dns:sip1.cy2.omega-telecom.net:5744
no early-offer forced
no midcall-signaling passthru media-change
voice-class sip profiles 311
preference 1
progress_ind setup enable 3
voice-class codec 1
dtmf-relay rtp-nte
no vad
NY4NTEAMS01#sh dial-peer voice summ
dial-peer hunt 0
111 voip down down .T 1 syst sip-server NA
300 voip up up 13232383594 1 syst ipv4:10.114.1.28 active NA
311 voip up up .T 1 syst dns:sip1.cy2.omega-t active NA
07-20-2023 03:31 AM
dial-peer hunt 0
AFAIKT dial peer 311 shows as up. What is you're specific problem that you have?
07-20-2023 04:24 AM
07-20-2023 04:29 AM
I would suggest that you address that question to SolarWind as the router command shows the dial peer to be up.
07-20-2023 05:50 AM
Yes, i contacted Solarwinds support.
Do you have the OID's used to poll the trunk status on your network?.
07-20-2023 05:53 AM
No I don't. We do not poll this from any management system. The use case we have for SIP option ping to monitor dial peer status does not extend outside of the voice gateways.
