CUBE: SRTP fails because of 2 valid audio m lines
I can not get SRTP working in the following Setup:
Unify/Siemens IP Phone ---- Unify/Siemens PABX ---- CUBE ---- CUCM ---- Cisco Phone
For the CUBE i am using a Cisco 4331 with IOS XE 16.07.01.
The PABX is sending a SIP Invite including 2 audio m-Lines, 1 for SRTP (SAVP) and 1 for RTP (AVP). (Please see the attached SIP Invite: SIP INVITE OSV-CUBE SANITIZED.txt)
The Cube answers with a 488 unacceptable media, and in the output of a debug ccsip all i see:
May 29 17:02:31.559 METDST: //128863/25495E0D801E/SIP/Error/sipSPICheckForkingCriteria:
 2 Valid Audio Mlines is not supported, hence disconnect the call..
Is this a limitation/Bug of CUBE not supporting 2 audio m-Lines? Are there any workarounds i could use to get SRTP working?
As a side note: It is not possible to use "pass-thru sdp..."
Any help/tip is welcome!
/Robert
8 Replies 8
M02@rt37
Hi @ROBERT SCHUKNECHT
Is it possible for you to share your dial peer configuration and your voice service voip menu.
Witch encryption for RTPdo you use on your CUBE?
Between your CUBE and CUCM do you configure SRTP too, or are you only with srtp to rtp internetworking mode on your CUBE?
Best regards
Hi Benode371,
between CUCM and CUBE i am using SRTP, also. And, SRTP is working fine when the call is initiated from the CUCM side.
What do you mean by "Witch encryption for RTPdo you use on your CUBE?"
Please find the requested config snippets attached.
Take a log with the following debugs and making a failed call -
debug ccsip message
debug ccsip error
debug voice ccapi inout
We should have more information in there to see what is happening. Also, are you doing a SRTP to RTP inter working through the CUBE or is it SRTP to SRTP end to end ?
Hi Nipun,
we want do SRTP to SRTP with fallback to RTP, if RTP is not possible between the involved Endpoints.
Please find attached the requested log of a failed call.
As you can see in the log the CUBE is not accepting the the first INVITE because the PABX is sending the INVITE with 2 Audio M-Lines (1 x RTP/SAVP and 1 x RTP/AVP).
*Jun  4 10:15:18.243: //52/405D47718035/SIP/Error/sipSPICheckForkingCriteria:
*Jun  4 10:15:18.243: //52/405D47718035/SIP/Error/sipSPIHandleInviteMedia:
 Media Negotiation failed for an incoming call
*Jun  4 10:15:18.243: //52/405D47718035/SIP/Error/sipSPIContinueNewMsgInvite:
 Unacceptable media indicated for INVITE
/Robert
Which encryption on your siemens pabx do you use? Is it in adequation with CUBE configuration?
Best regards
i am not sure what you mean by "Which encryption on your siemens pabx do you use?".
SRTP is working fine when the call is initiated from the Cisco side.
/Robert
Ok @ROBERT SCHUKNECHT
You have perhaps dissociated inbound and outbound dial-peer on your CUBE....that's the reason why it's OK in one way.
What about inboud dial peer on CUBE from pabx? Do you configure srtp fallback too?
Do you configure srtp on voice service voip ? Or in each dial-peer? Sha-32 80 ....?
Best regards
Currently i am using only 2 Dial-Peers
Dial-Peer 100 incoming from / outgoing to CUCM:
dial-peer voice 100 voip
 description --- TO AND FROM CUCM ---
 session protocol sipv2
 session transport tcp tls
 session server-group 100
 destination dpg 100
 incoming uri via 100
 voice-class sip profiles 100
 voice-class sip options-keepalive profile 100
 no voice-class sip error-code-override total-calls failure
 voice-class sip copy-list 100
 dtmf-relay rtp-nte
 codec g711alaw
 ip qos dscp cs3 signaling
 no vad
and Dial-Peer 200 incoming from / Outgoing To Siemens/Unify PABX
dial-peer voice 200 voip
 description --- TO AND FROM OSV ---
 session server-group 200
 destination dpg 200
 incoming uri via 200
 voice-class sip options-keepalive profile 200
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
Dial-Peer matching is working as expected. No errors there.
SRTP Fallback and also srtp-auth are configured globally under "voice service voip".
voice service voip
 no ip address trusted authenticate
 mode border-element license capacity 100
 media bulk-stats
 srtp fallback
 allow-connections sip to sip
 redundancy-group 1
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 modem passthrough nse codec g711alaw
 sip
  bind control source-interface GigabitEthernet0/0/0
  bind media source-interface GigabitEthernet0/0/0
  rel1xx disable
  header-passing
  error-passthru
  srtp-auth sha1-32 sha1-80
  asserted-id pai
  midcall-signaling passthru media-change
  midcall-signaling preserve-codec
  srtp negotiate cisco
  early-offer forced
  privacy-policy passthru
  pass-thru headers unsupp
  pass-thru subscribe-notify-events all
  pass-thru content unsupp
  sip-profiles inbound
  no call service stop
  send 180 sdp
Going back to my original question: Should CUBE accept 1 SDP with 2 Audio M-Lines?
/Robert
