CUBE will not register with SIP Provider-Debugs show nothing
Dennis Topo Jr
Level 3
Level 3
Hello all...
I’m new to voice and I’m interested in learning more. My main problem is, after much reading and tweaking, I still cannot get my CUBE gateway to register with my sip provider. I have a fully functioning Asterisk box behind a nat router here at my home office- works perfect...but I wanted to be a glutton for punishment and try to do it the Cisco way )....with CUBE and CUCM. Here’s my setup:
*CUBE on a GNS3 router 3725 running  3700 Software (C3725-ADVENTERPRISEK9_IVS-M), Version 12.4(25b)
Single interface mapped to my PC nic via GNS3- 192.168.0.11    IP routing disabled
*CUCM 8.6.2 running in VMWare player- 192.168.0.5
*Cisco\Linksys NAT router- 192.168.0.1 with appropriate ports forwarded to the CUBE
*Callwithus SIP account- separate account from my Asterisk setup
*IP Communicator softphone on PC- registered with CUCM
Connectivity is fine between all involved- can ping and resolve- I enabled debug ccsip all- and nothing so far- no activity\connection in.
Do I need to set up the trunk from the CUBE to CUCM to “trigger” the registration? I did try that as well, but not sure it’s done correctly. Or maybe this is not possible using GNS3??- I did not read anything definitive either way. Appreciate any help guys...
Here’s my CUBE config:
! No configuration change since last restart
! NVRAM config last updated at 14:51:27 UTC Sat Jul 13 2013
version 12.4
hostname cube-1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
ip domain name dtech.local
ip name-server 192.168.0.6
ip name-server 192.168.0.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
interface FastEthernet0/0
ip address 192.168.0.11 255.255.255.0
no ip redirects
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.10 255.255.255.0
no ip route-cache
shutdown
duplex auto
speed auto
ip default-gateway 192.168.0.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior g729-variants static-pt
dial-peer voice 1 voip
description Out to CallWithUs
destination-pattern .T
session protocol sipv2
session target dns:sip.callwithus.com
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description To CUCM
session target ipv4:192.168.0.5
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
authentication username 1234 password 4321 realm sip.callwithus.com
retry invite 3
retry register 3
retry subscribe 3
registrar dns:sip.callwithus.com expires 180
sip-server dns:sip.callwithus.com
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
ntp clock-period 17179859
ntp server 192.5.41.40
end
5 Replies 5
brmeade
Level 9
Level 9
Does the gateway successfully resolve the IP for sip.callwithus.com?  Look at doing some DNS debugs.  An A-record probably isn't enough.  You need an SRV record for that host as well.
Brian.....it does resolve. I'm able to ping sip.callwithus.com from the gateway and the correct IP is returned. I would still need a srv record for the host on my DNS server?
Ok... well..at least I got some debug activity now-- I added the credential line to sip-ua as such:
sip-ua
credentials username 450 password 1111 realm callwithus.com
authentication username 450 password 1111
retry invite 3
retry register 3
retry subscribe 3
Now getting an Unauthorized return: Any ideas anybody?
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP  192.168.0.11:5060;branch=z9hG4bK52631;rport=59987;received=68.194.127.35
From: "450" <>450@sip.callwithus.com>;tag=3CB5C-8B8
To: "450" <>450@sip.callwithus.com>;tag=05fa965d41f3adc51e16f9a7acf1c273.be8d
Call-ID: 1E8ADCD1-2BDE11D6-8002C0B2-8CF6ED57
CSeq: 6 REGISTER
WWW-Authenticate: Digest realm="sip.callwithus.com", nonce="UeSdLlHknAKCjHV4OP0/M1ZFJrp5W8YZ"
Server: CWU SIP GW
Content-Length: 0
Try realm sip.callwithus.com in "credentials".
I tried that Paulo...thanks...but no go. I've tried so many combinations in the sip-ua. Took the credentials line out- tried with and without the "sip".callwithus.com- added the no remote-party-id.
The current sip-ua and register and recieve debugs are below if anybody else wants to take a stab. This should not be so hard! Fustrating! Anybody deal with setting up a trunk for callwithus.com ??  Thanks again all
sip-ua
credentials username 169 password 1111 realm sip.callwithus.com
authentication username 169 password 1111
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sip.callwithus.com expires 120
REGISTER sip:sip.callwithus.com:5060 SIP/2.0
Via: SIP/2.0/UDP  192.168.0.11:5060;branch=z9hG4bKFBBC
From: "169" <>169@sip.callwithus.com>;tag=B8DBC-1C13
To: "169" <>169@sip.callwithus.com>
Date: Tue, 16 Jul 2013 20:53:33 GMT
Call-ID: 1E681327-2BDE11D6-80028CB2-3561462B
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1374008013
CSeq: 16 REGISTER
Contact: <169770968>
Expires: 180
Authorization: Digest username="169",realm="sip.callwithus.com",uri="sip:sip.callwithus.com:5060",response="1467693bb958235d7eeffa30354a5a4c",nonce="UeWz+VHlss0t7jKwQ1GLMOlGkuqdVCWa",algorithm=md5
Content-Length: 0
Jul 16 20:53:33.720: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 204.74.213.5:5060
Jul 16 20:53:33.724: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x658CBBA8
Jul 16 20:53:33.732: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP  192.168.0.11:5060;branch=z9hG4bKFBBC;rport=52764;received=68.194.127.35
To: "169" <>169@sip.callwithus.com>;tag=05fa965d41f3adc51e16f9a7acf1c273.bf2c
CSeq: 16 REGISTER
WWW-Authenticate: Digest realm="sip.callwithus.com", nonce="UeWz+VHlss0t7jKwQ1GLMOlGkuqdVCWa"
Server: CWU SIP GW
Content-Length: 0
