05-22-2015 03:26 PM - edited 03-17-2019 03:05 AM
Dear All,
I have CUC 7.1 and CUCM 10.5 i make integration as SCCP is working, But when i try to add CUCM as AXL Servers give me this error "Failed to send message to remote AXL server. Please check error log for more details."
How i can solve this problem ??
Best Regards
05-22-2015 08:12 PM
was this setup working fine for you earlier, or is this a new config ? check the below configs!
check if the Cisco AXL Web Service is activated in CUCM from servicability page
make sure that the CUCM AXL userid and password MUST be the same as the one used in CUC
also check if you configured the controlled devices to the AXL_Admin Application User account
Venkatesh
05-23-2015 06:59 AM
Dear venperum,
I checkd everythings, But it's not working Also...
05-23-2015 07:05 AM
Is your AXL user assigned to the AXL API user group?
Make sure you do not use any special characters in your password.
What if you specify your CUCM admin account (master one you login with) as the axl user?
05-23-2015 07:13 AM
Dear Chris,
-Yes it's assign to AXL API group.
-i don't have any special characters in my password.
-i don't understand the last point ?
05-23-2015 07:17 AM
For the last point I suggested to use your master CUCM username as the AXL user, i.e. ccmadministrator, admin, etc. whatever you have defined as master application account on CUCM.
If that does not work you may need to look through AXL logs.
Side question, are you attempting to bring in users from CUCM to UCXN? Ideally you would use LDAP for which you would not need to define any AXL integration.
Chris
05-23-2015 07:27 AM
i try to use my master username & password as AXL user, but is not working.
Yes i attempting to bring user from CUCM ?
But, how i can check the AXL logs ?
05-23-2015 09:49 AM
Make sure you are using the correct AXL username that is it is case sensitive.
regds,
aman
05-23-2015 02:27 PM
Dear Aman,
i use it as case sensitive, Also not working..
05-24-2015 05:52 AM
Hi Ahmad,
I was just checking the bug which could be related to the problem u are facing.I suggest opening TAC case.
regds,
aman
05-23-2015 06:19 AM
Venkatesh provided excellent time (+5) in addition CUC 7 is compatible with CUCM 5+ as seen here using SCCP:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Also, there should be devices assigned to the AXL user, simply ensure the credentials match on both sides and that the credentials policy does not force the password to expire, etc.
