CUC Bulk update partition on users
raghav0122
Is there a way to update partition on random users in CIsco unity connection 11.5  through Bulk tool
Chris Deren
You should be able to do this by going to Users, then in upper right corner press Go for "Bulk Edit by CSV", select the CSV file with user ALIASes, after upload and verification you will be able to check "Partition" and select desired partition from the drop down. This assumes all users in the job are changing to the same partition.
TONY SMITH
You can use Bulk Edit for this sort of change, it's convenient if you can show all the relevant users on one page.   Do a search or something to bring up the list, tick the ones you want to change and select Bulk Edit from the bottom.  You can then edit individual fields and the change is applied to all the selected users.
Chris Deren
I thought it could be done with an Update User CSV, but that doesn't seem to support a column for partition.
Thanks Chris. I am able to update the partition now.
