CUC Encryption
refram
Level 3
Level 3
We are going to implement SRTP everywhere with CUCM, CUC, and the voice gateway.  We are also going to be doing either IMAP or single inbox for voicemail going to Outlook.  We plan to do secure voicemail to Outlook.  What we're wondering is what happens with those secure messages.  We assume that when someone leaves the message, SRTP will encrypt everything.  What happens when the message is actually stored on the CUC box?  Is it encrypted there?  If it isn't encrypted is it reachable?  We are also assuming that when listening to the message using ViewMail, SRTP will encrypt the voice packets.  But are there any unencrypted temp files anywhere that we need to worry about?
7 Replies 7
cjoseph23
Here are some links to a Q&A about sRTP on the routers as well as the security guide for Connection.  I will ask around here about some of your questions and post back if I get anymore info.
Media Authentication and Encryption using Secure RTP on Cisco Access Routers.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd8016c49f_ps5854_Products_Q_and_A_Item.html
Securing the Connection Between Cisco Unity Connection 8.x, Cisco Unified Communications Manager, and IP Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/security/guide/8xcucsec030.html
The entire guide:
Security Guide for Cisco Unity Connection Release 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/security/guide/8xcucsecx.html
cj
Thanks CJ.  I'll be interested in seeing if you come up with something.
Did you find anything on this? I am interested in this too? Is the message encrypted on the Uconn server?
Srini
I asked around and most of the guys here don't believe the message is encrypted on the CUC box but I can't confirm that for sure.  They compared it to sending data accross a VPN tunnel - the data gets encrypted on transmit and then unencrypted on recieve.  Not sure how valid that is or how good of a comparison it is.
You can mark the messages as "secure" to add some security to the message.  See this link
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/security/guide/8xcucsec070.html#wpxref68976
cj
Yep I have seen that link on securing messages but the customer wants to know from a PCI standpoint if the message on the box is also encrypted because it might have someone’s credit card info and they don’t want that to be tapped into..
Srini
Thanks for making the effort CJ.  I just got official word today from a Cisco guy who looked into it for me too.  To quote him:
The messages are not encrypted at rest on the CUC server.  However, the server is locked down such that no one has root access except Cisco TAC.  Which  makes it extremely difficult if not impossible to gain access to the messages.
There are no temp files because the secure messages are streamed from the server to interface.
As it turns out I have seen a method one can use to get access to root on a CUCM server, but - much like password recovery on a router - if you don't have physical access you can't perform the trick.  I'm also pleased about the temp files not being created.
Perfect thanks for the information
Srini
