IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5567 Views
  • 14 replies
I currently have a router with the following modules NM-HDV2-2T1/E1 with VWIC2 2MFT T1/E1 and a separate VWIC3-2MFT T1/E1 All to be used as E1 so giving 6x  E1 ports in a 3945 IOS 15.X router. The router will only be used for E1 no conf or transcodin...
iptuser55 by Level 6
  • 514 Views
  • 5 replies
Hello,Everytime I try to search for a phone or anything on my call manager by clicking the find button I get this message"Failed to create ASP object for:_Remote Scripts/rs_device.aps.". It was working fine before any suggestions on how to fix this i...
I have  the following cards in a router to be installed but I need to check the required DSP`s as I need to move some around to another router. I checked with the DSP calculator but need a 2nd opinionNM HDV2-2T1/E1 x 2 portsVWIC2 2MFT T1/E1 x 2portsV...
  • 336 Views
  • 3 replies
HiI'd like to know if the "Wake Up by pressing any button" feature will be supported on the IP 79xx series phones.According to the design guide and other documentations that I could find, this feature is currently supported on 69xx, 89xx, 99xx series...
cminard by Level 1
  • 1129 Views
  • 2 replies
I have a Cisco 2811 Router, and I'm trying to figure out what the actual amount of phones are that it can support.  The Cisco literature says the SRST call manager express supports 36 phones for the 2811, but in the config for Max-ephones it says up ...
My new company has their VG`s in the basement comms room . The idea is that the analogue port will be run up to the floors 15+ via teh building cabling structure other projects put the VG`s on the floor concerned. In the back of mind I`m sure there i...
  • 616 Views
  • 2 replies
Hi, i've a question about the ESW contract for a CUCM solution. When i build a BOM with the configuration tool for a CUCM solution and i add the ESW contract, the tool also add automatically the code CON-ESW-CMBUNDK9 relative to the CCX bundle, note ...
cbrasolin by Level 4
  • 3648 Views
  • 1 replies
