11-25-2012 02:38 AM - edited 03-16-2019 02:22 PM
Hi Experts,
I want to setup my main Central number coming to our company go to Unity Connection call handler, play a greeting, allowing the user to enter an extension or to hold for an operator. I have created a CTI route point with DN 2800(DID), forwarded all to VM. and configured SIP Trunk in cucm 7.1.5 to CUC8.5,
On the Unity Connection, I have created a System Call Handlers-AddNew-Extension = 2800-save, when i dial 2800 from the mobile/ip phone, CUC plays the message "Sorry, CENTRAL NUMBER DOES NOT EXIST.
Could you please share the exact steps from begining or what i am missing in the configuring.
Thanks and Regards.
11-25-2012 06:45 AM
Hi John
Look into this thread, I think is the same are you facing or can help you.
Please rate all posts using the stars
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
11-25-2012 07:48 AM
Is normal voicemail working OK for you or is this AA the only thing you have?
What digits are you seeing on CUC when using RTMT port monitor or port status monitor available for download here:
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Chris
11-25-2012 11:25 PM
Voicemail is working good.
I have Installed Remote Port Status Monitor by entering the cuc ip address but nothing is shown in that.
I am trying to set up a AA the configurations i have done is:-
CUCM7.1.5 side create CTI Route Point with DID(2800) with Forward all Enable,Sip Trunk pointing to CUC8.5.
CUC side created system call handler with proper css and partition and Extension 2800-Standard greetings-CallerHear:Nothing,
check :
when i dial the 2800 number it is asking to "Enter the Number you wish to transfer to -when i enter the DID (2801)or Normal(3099) extension it is saying you cannot be transfer to this number check the number and try again.
Please advice me where i am missing the configuration
11-26-2012 12:07 AM
This problem related to the restriction table which restrict any number outside the unity connection
check the restriction table and allow the call to be dialed.
You can modify the predefined restriction tables, and you can create up to 100 new ones. You can also add up to 100 dial strings to a table. New dial strings are automatically inserted into the restriction table as Dial String 0. Note that the order of the dial strings is very important because Cisco Unity Connection sequentially compares a phone number to the call patterns in the restriction table, starting with Dial String 0. If a number matches more than one call pattern, the number is handled according to the first call pattern it matches.
You can indicate call patterns by entering specific numbers or by using the following special characters as wildcards:
* | Matches zero or more digits. |
? | Matches exactly one digit. Use? as a placeholder for a single digit. |
# | Corresponds to the # key on the phone. |
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag110.html
11-26-2012 04:11 AM
Thanks. Dear mrmhar. It helps.But Now the call is being transfered to the extensions with no voice stream on both the side.
11-26-2012 09:20 PM
please help me out.
