03-20-2016 02:26 AM - edited 03-18-2019 11:51 AM
i am using cucm ver 10.5.1.X and it is fully synced with LDAP.
as today i seen one user is not showing in cucm end user section.
i resync and restart Cisco directory service but still not able to see that user in CUCM end user section.
anyone know what is issue and how to fix it?
last time i used one cisco document and with command section of cucm cleared user search history and it was showing users.
but now i am unable to find that document and apply steps on cucm so that find user in cucm end user section.
Solved! Go to Solution.
03-20-2016 07:46 AM
Is this user in a container that is covered by your LDAP integration search base, or was the user perhaps moved to different contained?
Was the user possibly disabled in LDAP?
Do you have any filter on your LDAP integration, if so what is the filter?
03-20-2016 07:46 AM
03-20-2016 09:11 AM
thanks..
let me check
03-20-2016 09:11 AM
I am not aware of the commands, but I would look at the dirsync logs for clues.
03-20-2016 12:58 PM
Does the user has something in the surname field??
if it's empty it won't sync
03-20-2016 09:37 PM
yes..
it has all required field configured in LDAP.
02-22-2019 12:29 AM - edited 02-22-2019 12:32 AM
You're right Jaime, surname field on AD users wasn't set in my case and that fixed the problem. Thanks.
01-18-2021 04:43 AM
Thank you Jaime,
Solved my case
03-20-2016 10:55 PM
Thanks Chris..
i seen that user was disabled in LDAP...
