12-02-2016 10:26 AM - edited 03-17-2019 08:50 AM
All, We recently upgraded a three server CUCM cluster to 10.5.2 SU3. Since then we noticed that a phone will be listed as registered on only one of the two subs, and listed as "none" or unregistered on the other sub. As a phone can talk with only one sub at a time. Connectivity between both servers in the cluster is fine. All services are up. Everything worked before the upgrade. Any ideas???
Thanks....
Solved! Go to Solution.
12-02-2016 12:34 PM
You can sometimes fix this by rebooting the RIS DB service on all three servers (non-service impacting) but usually a full cluster reboot is required to fix this.
12-02-2016 12:34 PM
12-05-2016 04:45 AM
James,
I restarted the RIS DB on all three servers via the Serviceability GUI and it fixed the problem!
Thanks and have a great Cisco day.
Kirk E.
