01-15-2017 06:35 AM - edited 03-17-2019 09:11 AM
Hi Friends,
I am tasked to change Hostname and DNS Setting (Primary DNS IP, Secondary DNS IP and DNS Domainname).
My Voice setup contains:
CUCM (5 Nodes) Ver 10.5.2
CUC (2 Nodes)
IM&P (1 Node)
Questions:
Is there a sequence on which Role should go first (like CUCM First, CUC Second, IM&P Third)
Is there a sequence on Which Node to go first (like Pub First followed by Subscribers)
Is there a sequence on Which setting need to go first (Hostname First & DNS Setting Second).
Do i need to stop Replication before performing this change.
I went through the below document on DNS Change and Licensing Re hosting procedure
Any other Additional Inputs or surprises anyone has come across with respect to 10.5.2
01-15-2017 06:53 AM
Please use below link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/10_0_1/ipchange/CUCM_BK_C3782AAB_00_change-ipaddress-hostname-100/CUCM_BK_C3782AAB_00_change-ipaddress-hostname-100_chapter_011.html
If you have Prime Collaboration, this will be very straight forward
01-16-2017 06:06 PM
Hi Mohammed,
I am following the link you sent - strictly. I have not explored much on Prime Collaboration - will give a try on that too.
Thanks.
01-15-2017 06:04 PM
No 1 thing is that you MUST take a complete DRS backup and as well as the VMWare snapshot, so that just in case something goes unplanned, you can restore the things back.
Secondly, I wanted to know if you have any Public CA signed Certificates anywhere in the system if yes, then you MUST get a new certificate from the Public CA (this is the case even if you have a Private CA, but Private CAs are far less expensive than the Public ones, hence easier to do it)
Q. Is there a sequence on which Role should go first (like CUCM First, CUC Second, IM&P Third)
I would start with the CUCM, and then IMP. CUC can be done independently, means it doesn't matter when you are really doing the CUC (it may be the first or the last)
Publisher is always the first one to make the changes.
Are you changing the DNS Server IP Addresses or DNS Domain Name or just the hostnames?
If it is DNS Servers only, then make sure all the info has been created in the new DNS Server
If DNS Domain change, then make sure all the information (Forward and Reverse Lookup Zones along with A Records, SRV Records and the PTR records have been created and tested 100% before you make the changes!!)
No, I have never done that.
01-16-2017 06:03 PM
Hi Wilson,
Thanks for your inputs and answers to your queries below:
Certificates: We are using self-singed CA.
Network Identifier Changes: We are changing all the four settings - Primary DNS IP, Secondary DNS IP Address, DNS Domain Name and Host Name. What is the sequence here - which setting needs to go first.
Thanks.
01-16-2017 07:05 PM
If would have started in the following steps after taking DRS backups and vSphere, also run the RTMT and check all the CTI Ports, CTI RPs and device counts that are registered are counted for.
More over, I assume there is NO UCCX involvement in this.
1. New DNS Server Configuration
a. Forward Lookup Zone (create if not already existing)
b. Create the Domain Name in the Zone
c. Create all the A and CNAME (if needed) entries in the new domain
d. Create all the SRV records for the IMP Servers
2. Test the new DNS Server Configuration using nslookup command. == VERY VERY Important step!!!
3. Change the Hostname and the IP Address on the CCM Pub, follow the same on the CCM Subs
4. Restart the cluster
5. Change the IP Address, Hostname and the DNS configuration on the IMP Pub Server and then Sub Server (if any)
6. Restart the cluster.
Wait for all the servers to come back up, run the RTMT and make sure all the devices are showing up as Registered
Once verified then, proceed to Step 7.
7. Change all the Voice Gateway references (dial-peer addresses and the Trunks / MGCP IP Addresses and MGCP Domain info is updated)
By this time all should be good with the CCM, try making calls EXCEPT the voicemails everything should be good.
CUC:
1. Change the IP Address, Hostname and the DNS Server settings on the Primaryr first, restart the Primary and follow the same on the Sec
2. Restart the cluster
3. VERIFY that DNS configuration is 100% accurate using nslookup command
4. Change the references for the CUCM in the Telephony configuration for the CUC
5. Restart the cluster
6. Verify there are no err messages in RTMT
At this point all should be good between the CCM and CUC
IMP
1. Change the IP Address, Hostname and the DNS Server on the Pub, restart the server, follow the same on the Sub
2. Verify the configuration using nslookup command (VERY IMP)
3. Restart the cluster
4. Verify in the Presence Admin page that all services have come back ok
6. Regenerate the CSR all the CA Signed Certificates that are being used and re-apply to the IMP, CCM and UC hosts
Run the tests
01-18-2017 10:13 AM
Hi Wilson,
The change is only for Hostname of cucm (NOT the IP address of cucm) and to DNS entries. From your comments i understand that i have to change Hostname first and then change the DNS related configuration.
Thanks.
10-30-2018 05:27 AM
I am assigned to change Hostname,IP Address and moving the servers to a different Host,where the DNS server is also different.
CUCM (3 Nodes) Ver 10.5.2 (1 Pub & Sub 1 in DC 1)only Publisher is moving one subscriber will stay in the same DC
CUC (2 Nodes) None of them are moving
CUEAC(Standalone) 10.5 moving along with Publisher to different DC where CUCM SUB02 is residing.
AQM(Recording server) along with Publisher is moving.
Vsphere client 5.0.0 I can see all these device which i need to move on the same Host.
Need your input to do the same.
03-03-2019 04:49 AM
03-03-2019 05:26 AM
03-03-2019 05:27 AM
