CUCM 10.5 , Silent ringtone on Call-Waiting call
Ahmed Khalefa
Hello All,
Recently , one of our customers purchased a 3rd Party SIP Phones , and they are registered to the CUCM as 3rd Pary Basic SIP Phones ,
Phones are working normally , without any issue , till the customer discovered an interesting issue ..
When Phone A , calls Phone B ... and we have an established call ..
Now Phone C , tries to call Phone A ..
- Phone A : hears a beep tone ( which is the one for waiting )
- Phone C : hears nothing .. complete emptiness .. and this is the issue
they raised a Ticket with the 3rd party vendor , and they said that the Phone A sends a SIP Message 182 ( Queued ) to the CUCM
but after checking the CUCM Traces , the CUCM didn't sends any ACK or any message to reply ..
I tried changing the "SIP Rel1XX Options" from Disabled to "Send PRACK for all 1XX messages" , but that didn't change any thing ..
also , googled the issue and found that CUCM chooses to ignore this message ... as per this document :
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/sip_msg/line_std/10_0_1/CUCM_BK_CC69BCF6_00_cucm-sipline-messaging-std-100/CUCM_BK_CC69BCF6_00_cucm-sipline-messaging-std-100_chapter_01.html#CUCM_CN_S33CFD74_00__table_2433D78BFB80416EAE12B4734...
Can any one help with such issue ?
Thanks A lot,
Ahmed Salah
vasank
Hi Ahmed,
What is the expectation here? 182 is a provisional message indicating the proxy that call is in queue, which does not necessarily translate to 180 ringing or 183 session progress, if the third party sip phone sends a 183 session progress after 182 then it would make sense to perform audio cut through.
Vasanth
7 Replies 7
vasank
Hi Ahmed,
Vasanth
Hello Vasanth,
it seems that your answer says all .. as i took a SIP Trace from  a working Cisco SIP Phone 99xx , and the message i sent as 180 Ringing , instead of 182 ...
So , i believe that the issue is related to the 3rd party vendor ..
Thanks A lot,
Ahmed Salah
Thanks Ahmed, glad it helped.
Vasanth
Vivek Batra
Can you please share the SIP traces of second call on both the call legs viz from C to CUCM and CUCM to A?
By the way, third party SIP phones are from which vendor?
- Vivek
Hello Mohamed, Vivek,
traces are in the attachment below .
i took a trace from the CUCM , with below scenario :
1722 : 10.1.35.252 >> Phone A
1000 : 10.1.30.107 >> Phone B ( VM System : not Cisco )
1718 : 10.1.35.236 >> Phone C
I used TranslatorX and found that when the 1722 is having an established call with 1000 , and 1718 tries to call to 1722 , 1722 sends a 182 SIP Message ( Queued ) to the CUCM .. that's all ...
Thanks A lot,
Ahmed Salah
Hello All,
any luck finding any thing inside CUCM Traces?
Please get SIP real time trace from CUCM using RTMT and share a snapshot. This will help us to understand the call flow. This might be related to voice cutthough and early-media but lets see
