CUCM 11.5 LDAP Filter based on OU
jayage
Hello
is it possible to filter users sitting in one organization unit?
We got the following hierarchy:
OU=Users,DC=corporate,DC=com
OU=BU1,OU=Users,DC=corporate,DC=com
OU=BU2,OU=Users,DC=corporate,DC=com
OU=BU3,OU=Users,DC=corporate,DC=com
BU stands for business unit, our subsidiaries. Our ldap directory in CUCM is currently set to sync everything above Users and we don't want to add different directories but BU3 shouldn't get imported. Any suggestion on how to do that? The ldap admin doesn't want to add a security group to these users in BU3 and some of the phone numbers used there are similar to those in other BUs.
Thank you
Jaime Valencia
Another option is to control which OUs you can sync is by granting or denying read permissions to the user you're using to create the integration.
You'll only sync what they have read permissions for.
java
if this helps, please rate
Chris Deren
Sure, with current versions of CUCM (I believe as of 10.0) you can build up to 20 LDAP directories, in prior versions it was 5.
Jaime Valencia
java
works great, thank you
