CUCM 11.5 LDAP Filter Feature Group Template not applying Home Cluster checkbox
richard Beck
I have an LDAP feed setup to import users from an OU. I have created an applied a feature group template that "checks" the home cluster option as well as the Enable users for unified CM IM & Presence. When I run the LDAP sync it will not apply those settings to the user.
Any ideas as to why? this user was already on the CUCM from a different feed.
RB
Jaime Valencia
If the user was already in CUCM, and then you change the template, those changes do not replicate to existing users, they will only be applied to new users.
java
if this helps, please rate
Jaime Valencia
java
Crap. That is what I was afraid of. How do I work around this? I already have about 13000 employees who need to updated. BAT tool?
Yes, you'd need to use BAT to change that setting
java
When using the BAT tool, I get an error saying "LDAP Sync status is enabled. Some fields cannot be updated."   I'm only trying to update 2 fields for "Enable User for Unified CM IM" - set to true and "UC Service Profile" name.  So how do you update existing users?
