11-24-2018 09:57 AM - edited 03-17-2019 01:46 PM
We are not getting option to add VWIC3-1MFT-T1/E1 card in MGCP configuration .
CUCM version 11.5
on VIC and slot 0 option showing only - NM4-4WIC-MBRD
on VIC and slot 1 option showing below cards ,
NM-HD-1V
NM-HD-2V
NM-HD-2VE
EVM-HD
NM-HDv2-0PORT
NM-HDv2-1PORT-T1
NM-HDv2-1PORT-E1
NM-HDv2-2PORT-T1
NM-HDv2-2PORT-E1
Am using VWIC3-1MFT-T1/E1 card in 2921 router , but in CUCM am not getting this card for MGCP gateway configuration .
Solved! Go to Solution.
11-25-2018 04:42 PM
I'm guessing you have not clicked on save after choosing that option.
11-24-2018 08:56 PM
11-24-2018 09:59 PM
Dear ,
when we select NM4-4WIC-MBRD in card sub menu is not opening .
R/
Praveen
11-25-2018 04:42 PM
11-28-2018 11:08 AM
Thank you , after saving am able to other options ,,VWIC3-1MFT-T1/E1.
