07-04-2016 05:06 AM - edited 03-17-2019 07:26 AM
I have CUCM 11 and everything is working fine except outgoing call.
There is at least 10 - seconds delay when the CUCM place the call to the Voice gateway!!
can you help me please
best regards
07-04-2016 05:14 AM
Its most likely due to an overlapping dial plan. What is the exact Route pattern that you have configured to send the calls out? Check under Call Routing > Route Plan Report on cucm page and download the route plan and see if there are any overlapping patterns ( example 9.1XXXXXX and 9.! ).
If you want you can provide the Route pattern details and Route plan report on this post and we can check it.
Manish
07-04-2016 06:22 AM
Tanks Manish Gogna for your answer,
could you please to answer me how many time take the call extren via SDA
07-05-2016 02:16 AM
Can't understand what you are asking here, can you please rephrase or explain in detail.
Manish
