01-11-2021 11:55 PM
Hello all,
We are planning for procure flex plan for our new cucm and unity 12.5.
how licencing will be done in flex plan and licensing model for cucm 12.5.
Solved! Go to Solution.
01-13-2021 04:00 AM
01-12-2021 12:29 AM
Right approach would be to contact your Cisco Account Manager aligned for your organization.
Depends upon, there are 3 models, knowledge user licensing, named user and active user licensing.
01-13-2021 12:19 AM
Hi Ritesh,
In 12.x licensing is smart licenses and to make cucm complaince we use direct or on-prem Satellite..so my query is if customer buy flex plan then how this will communicate to cssm to make cucm complaince?
01-13-2021 03:55 AM
It’s the same , Flex only drives the licensing into the smart license portal for you to draw from , on a subscription basis. It’s still the same smart licensing.
01-13-2021 04:28 AM
Thanks Ashish & Adam,
This is the answer which i am looking..
01-13-2021 04:00 AM
