CUCM 5.1 Phone Support
I have customer running CUCM 5.1 and he recently bought a 6921 ip-phones, I have checked online and I cant find if it supported or not.
And cisco is not support me since its End of Support.
Please let me know.
Aman Soi
you need min. Call manager version 7.1.x for 6921 to work.
you can refer datasheet which says
The phones are supported in Cisco Unified Communications Manager and Cisco Unified Communications Manager Business Edition Versions 7.1.2 and later using Skinny Client Control Protocol (SCCP) or SIP with Cisco Unified Communications Manager and Cisco Unified Communications Manager Business Edition Versions 7.1.5 and later
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-6921/data_sheet_c78-541534.html
you need to upgrade Call manager to at least Call manager 9 or above so that Cisco can support.
regds,
aman
5 Replies 5
Aman Soi
regds,
aman
Is there a device pack for cucm 5.1 or not.
Many thanks for the quick support.
Device pack is not going to help since u require min. Call manager version 7 first. Regds, Aman
Hi.
To add a tip to what correctly mentioned by Aman (+5 A), here is a link to verify supported endpoints by CUCM 5.X
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Carlo
Please rate all helpful posts "The more you help the more you learn"
[+5] to Carlo.
regds,
aman
