CUCM 6.0 settings dont take until reboot
sgoodman
I'm running a CUCM 6.0 system and no settings take effect until the system is rebooted.  Whether its a simple name change on a extenstion or changing a translation pattern.  Also rebooting phones from the web interface has no effect.  I have run a replication repair between the SUB and PUB with no resolution.
Any help in troubleshooting this strange issue would be greatly appreciated.
9 Replies 9
thisisshanky
Level 11
Level 11
so the data u change does get stored in the db, but it looks like none of these changes get pushed out to the phones which partially may be an issue with the TFTP service..do you have good replication status between the servers ? have you tried resetting phones from both servers ? was a patch or anything recently applied ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for the reply, i would agree the changes get stored in the DB, however its not just phone changes that dont take until reboot, it could be any system changes as well.
Replication status is good.
No patches have recently been applied as far as i have been told (I have not been managing this system for the past 6 months, and when issues came up i was asked to take a look)
TFTP service is running and phones appear to pull files from TFTP with out issues.
Which version of CUCM are you on?
I remember a major issue in 6.1(2) which meant that changes made to the database didn't take place until the CallManager service was restarted. This was fixed in 6.1(3).
HTH. Barry
Barry i am running 6.0.1.  do you think the same issue?  Do you have a link to the article referencing the issue?
srsivara
This sounds like CSCso93220. please use the cisco bugtoolkit to pull info on this defect. 6.0.1 is affected by this bug. Basically, an affected server's 'show tech notify' output will be missing the 'ccm' component
Yup; looks like the same bug I found in 6.1(2). You'll need to upgrade to fix this issue.
HTH. Barry
I wish this were the case, but when i do a 'show tech notify' from both the publisher and subscriber 'ccm' is listed in both.  The bug report also references version 6.1.2.
My Version:
Active Master Version: 6.0.1.1000-37
Active Version Installed Software Options:
cmterm-devicepack6.0.1.2116-1.cop
admin:show tech notify
-------------------- show tech notify --------------------
Database Change Notify Monitor
Msg I 0/1 P 420 DB 0
0 I   0 P   0 H   0 T   0 S   3 DbTraceMon
1 I   0 P   0 H   0 T   0 S   0 DbIPsecMon
2 I   0 P   0 H   0 T   0 S   3 Undefined[127.0.0.1]:32792
3 I   0 P   0 H   0 T   0 S   1 SyslogAlerts
4 I   0 P   0 H   0 T   0 S   2 EM App[127.0.0.1]:32805
5 I   0 P   0 H   0 T   0 S   0 IPMA Trace Dialrules[127.0.0.1]:32814
6 I   0 P   0 H   0 T   0 S   2 Cisco WebDialer[127.0.0.1]:32816
7 I   0 P   0 H   0 T   0 S   0 EM Util[127.0.0.1]:32821
8 I   0 P   0 H   0 T   0 S   8 DialedNumberAnalyzer[127.0.0.1]:32834
9 I   0 P   0 H   0 T   0 S   2 LpmTool
10 I   0 P   0 H   0 T   0 S   1 CCMAuthentication[127.0.0.1]:32848
11 I   0 P   0 H   0 T   0 S   2 License Manager Trace[127.0.0.1]:32890
12 I   0 P   0 H   0 T   0 S   3 License Mgr[127.0.0.1]:32894
13 I   0 P   0 H   0 T   0 S   2 DRF Master Trace[127.0.0.1]:32899
14 I   0 P   0 H   0 T   0 S   2 DRF Local Trace[127.0.0.1]:32904
15 I   0 P   0 H   0 T   0 S   2 Trace Collection Service Trace[127.0.0.1]:32913
16 I   0 P   0 H   0 T   0 S   2 CDR Repository Manager Trace[127.0.0.1]:32920
17 I   0 P   0 H   0 T   0 S   3 CDRREPMGR[127.0.0.1]:32923
18 I   0 P   0 H   0 T   0 S   2 CDR Agent Trace[127.0.0.1]:32926
19 I   0 P   0 H   0 T   0 S   3 CDRAGENT[127.0.0.1]:32929
20 I   0 P   0 H   0 T   0 S   3 Undefined[127.0.0.1]:32937
21 I   0 P   0 H   0 T   0 S   1 RIS_CCM
22 I   0 P   0 H   0 T   0 S   4 RISDC
23 I   0 P   0 H   0 T   0 S   1 RISDC_PERFMON
24 I   0 P 141 H 141 T 141 S  10 Cisco CallManager Attendant Console Server[127.0.0.1]:32981
25 I   0 P   0 H   0 T   0 S   1 RIS_CTI
26 I   0 P   0 H   0 T   0 S   3 Undefined[127.0.0.1]:33000
27 I   0 P   0 H   0 T   0 S  40 CTFTP
28 I   0 P   0 H   0 T   0 S  11 IpVms
29 I   0 P   0 H   0 T   0 S   4 QRTSERVICE
30 I   0 P 147 H 147 T 147 S  26 CTIManager
31 I   0 P   0 H   0 T   0 S   1 RIS_CEF
32 I   0 P   0 H   0 T   0 S  10 SNMPCCM
33 I   0 P 306 H 306 T 306 S  80 ccm
Any other ideas?
Is the problem happening when you see the 'ccm' component in the 'show tech notify' output ? CSCso93220 causes the ccm component to be deleted from the notification list of database layer monitor - so the problem happens all of a sudden, and 'show tech notify' output at that point would be missing the 'ccm' component.
- Sriram
Please rate helpful posts !
Sriram,
This happens at all times, immediately after a reboot even.  CCM is always listed when i do a 'show tech notify'  however changes are never being reflected until after a reboot.
Any other ideas since this CSC doesn't seem to fit?
