CUCM 6.1.2: need phone inventory w/ serial num
radfordatk
I have looked at the reporting tools in CUCM 6 and figure out a way to retrieve serial numbers.  Selecting all details does not include serial numbers.   Is there a way to do this?
Leonardo Santana
Yes there is a way but is not a Cisco Tool, is the Serial Grabber this software will retrieve this info about the ip phone:
IP AddressPhone DNSerial NoMAC AddressModel No
I made a test with the following ip phones 7911, 7941, 7961, 7970, 7962 and it works. You have to put the network range that you wanna do a scan and the software will find the ip phones on the network.
Take a look here is in portuguese but you can find the software:
http://avvid.net/2011/01/20/inventario-de-ip-phones-cisco-seriais-de-ip-phones-em-massa/
Rate this if helps you
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Chris Lee
Something like this?...  Has Serial Number info and more...
Third party product  - though not free, you can ask for a free trial, download it, and run the report.  No handicapped software limits - only limitation is time period of trial use (15 days initially).
Hope this helps.
Chris
Could also try this if you’re using CUCM ver 9+
Will give you an audit/inventory of the phone's and lines configuration on the CUCM as well as the MAC and Serial of the phones .. free is well :-)
http://blog.netpacket.co.uk/2013/06/27/cucm-phone-invetory-tool/
cheers
alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
