11-10-2007 01:15 PM - edited 03-15-2019 07:10 AM
When I install CUCM6, I get "security configuration failed" and it goes to Database Access Security password page.
I am quite sure that I put the right password and NIC car is connected to the network, I even can ping the server ip address after I restart the server, but the CUCM is not installed at all.
Does anyone have experience with this?
Thanks in advance.
11-11-2007 10:10 AM
Is this for a Sub?
Are you using correct security password (not CCMAdministrator password) which
you entered during Call Manager installation?
Are you using static IPs? If not use static IP address...
Try to use an stronger password.
11-11-2007 05:30 PM
Appreciate your help.
Is a Pub with static IP address. I tried a password with 11 charactors with letters numbers and dash.
