IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hi,We are currently expecting problems with putting calls on hold and retrieve them later on. The problem is, that the call cannot be retrieved, the un-hold button is greyed out. This is only temporary. We are running IPCC version 7, this happens wit...
When I install CUCM6, I get "security configuration failed" and it goes to Database Access Security password page.I am quite sure that I put the right password and NIC car is connected to the network, I even can ping the server ip address after I res...
Resolved! 7914 Monitor
Hi Guys,CCME 4.1!voice-port 0/1/0 description FXS!dial-peer voice 401 pots destination-pattern 7677 port 0/1/0!I want to monitor the number 7677 on the addon 7914. Is this possbile?Thank you!
ken.chua by Level 1
  • 469 Views
  • 7 replies
Hi all,i have a big problem with subj. My provider has configure two headnumbers on one multiflex. First headnumber is connected on channels 1-15, secondary on 17-31. The channel 16 must be used as signalisation channel. How can I configure this on...
AK_1999 by Level 1
  • 856 Views
  • 11 replies
Hi,is it possible to backup a DMA-Database from a CCM 4.2.3 running on MCS-7835I-3.0-IPC1 and use this Backup tar-file for a fresh installation of 6.0.1 on another platform, for example MCS-7825-H3-IPC1 or can I upgrade only on the samemodel.kind reg...
m.toelke by Level 1
  • 312 Views
  • 1 replies
