Hi - We currently have a single site 2 node (1xpub and 1xsub) CUCM System
version: 7.0.2.20000-5 cluster.
Our customer has requested we re-address both the subscriber and the publisher to
accommodate their new address scheme. I have followed the doc
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/install/7_0_1/ipc
hange/ipchg701.html
and successfully changed the server ip and eth0 ip on the subscriber, however, when we try
to change the IP address on the Publisher using either the web ui (Settings > IP >
Publisher) or cli (set network cluster publisher ip) commands we recieve the error:
"This machine is the publisher and therefore the IP address cannot be modified. "
Can you help?
