CUCM 7.1.3 - File get activelog don´t work
wilsonsant
Level 6
Level 6
Hi Guys,
I am trying collect the any files using: file get activelog, but, don´t work. I am using the SFTP msftpsrv. I verify that there is communication between CUCM and SFTP Server, but, the folder generated stay empty and CUCM not is generate none message error. Any have idea about this?   Can be the SFTP Server?
Wilson
Jonathan Schulenberg
The Microsoft FTP Service is not SFTP, it is FTPS. Try FreeFTPd instead.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jonathan,
Thanks for your contact. The problem not is the SFTP Server. The customer informed to me that there was rule in the firewall. The problem was solved.
Wilson
