ā04-04-2011 12:31 AM - edited ā03-16-2019 04:18 AM
Dear All
I am wondering if is possible to access the CDR database on CUCM
What i mean is: Now the call manager send the cdrs automatically on an sftp server.Then we run an application which recieve the cdrs from there and put it on an other database (Run SQL)..I am wondering if is possible to access directly the CDR database on CUCM and take directly the CDRS from there..With out the need for the extra step(SFTP)
This is possible?
If yes , could you pls give me a specific infos?
Thanking you in advance
ā04-04-2011 12:54 AM
You can try this doc
https://supportforums.cisco.com/docs/DOC-14548
You can also read thru CAR docs
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_0_4/car/carrport.html
/divin
PS:Rate only useful posts!
ā04-04-2011 02:11 AM
thank you for your answer
In previous versions(version 4) it was possible to connect to the SQL server and query the CDR log. Is it possible to do that in 7.1.5 ?
As the server is linux based and itās not running SQL server, is there a way to query the database it stores the logs in ?
ā04-05-2011 12:11 AM
Does Any ones have an opinion regarding this?
ā10-17-2012 08:16 AM
Just curious if you ever figured this out? I'm running in to the same issue here.
