10-19-2011 08:08 AM - edited 03-16-2019 07:36 AM
We are using MS Lync with Call Manager 7.1.5 acting as the PBX. Whenever I add a route pattern to the SIP trunk that connects with Lync all of the calls on that trunk drops. If I just update an existing route pattern on tied to the trunk the call does not drop. Is this by design? Does it work differently in a newer version of CUCM? Is there a way to work around it?
10-20-2011 12:27 PM
sorry mate did not get the issue you are facing exactly, could you please explain the steps for each one.
Best Regards,
Odai Jeriss
10-21-2011 08:20 AM
We have several route patterns tied to one SIP trunk between Lync and CUCM. Whenever I add a new route pattern and tie it to that SIP trunk, all ongoing calls on that trunk are dropped.
Does that make sense?
10-21-2011 01:17 PM
yes, it is clear now. could you please go through the following:
1- enabled the CUCM traces to detailed level
2- adding that pattern and assigne it to the trunk
3- then do a testing call.
4- collect traces genarated during the test.
please attach the traces.
Best Regards,
Odai Jeriss
