Hi all,Anybody helps me to create a tcl script like as: Welcome to ABC. Please dial the extension number or 1 for your instruction. Thank you (Welcome.au) After press 1.au : Sale department press 3100, Financial department press 3101,.... Pr...
I'm looking for ways that we might improve the experience for users of our Communications Manager systems. In particular, I'm interested in User Pages enhancements (e.g., easy config of Single Number Reach), calling/phone features that the community...
hi all,is it possible to change the prompt during the two internal phone call connecting?the phones are all registered with the CUCM 6.1.3, and i have found the there are so many prompt files in the tftp management menu, but when i replace all tho...
cme call transfer issue
hello every oneI'm considering the 2N OfficeRoute http://www.2n.cz/en/products/umts/officeroute/tech-specs/ as a VOIP/GSM Gateway for my Cisco Callmanager 4.3Have anyone worked with \ Connect this product before ??? am interested in connecting it...
Hi all, We are using 2n officeroute as gsm gateway. and using PSTN lines as failover. Gsm gateway has got four sims. When all four sims are busy the fifth person dials a mobile number (mobile calls are routed via GSM gateway), CME tries to use...
Hi,Anyone has recommendation of ICT trunk troubleshooting guide for CCM ?Presently, I have a weird issue when a cluster calling to another cluster the distant cluster will heard 'breaking up' voice audio issue, which cannot heard properlyHave trace t...
Guys,I have a cluster of one publisher & subscriber which was working fine & database replication was also good.Due to some upgrade reason i had to reinstall only the publisher. I reinstalled publisher & connected it with subscriber.After reinstallat...
I have problem with mobile connect, the diverted number is not shown on the remote destination instead it shows one of a free un-configured extension number inside CM, this happen only when the diverted number is PSTN number, while for internal numbe...
I have a route group with 2 members, the first is a SIP trunk and the second one is a PRI line. The problem is, when a call is routed through the SIP trunk and for some reason the SIP gateway replies with "486 busy here" or "503 service unavailable",...
Hi,i have VG 3945 with the following:- 1 DID E1 going to PSTN (controller E1 0/1/1)- 1 DID E1 going to PSTN dedicated to Rightfax service (controller E1 0/2/0)- 1 DOD E1 going to PSTN (controller E1 0/1/0)- 1 PRI going to Rightfax server (controller ...
Hi ExpertsI am testing one scenario for builtin vpn client on Cisco IP Phones, for this I have to configure VPN-Group & phone-vpn-features in CUCM. I didnt find the option for VPN-Group in advance feature tab in CUCM, i am using CUCM 8.5. We have to ...
Hi , Sorry for buzzing the forum with unity issues, but we are in the process of upgrading to the unity server 8.6 ( latest version ) from the current 4.2.x, and at the same time we would require some information on its integration with the microsoft...
Hi , A colleague is getting the following error message on the unity server while adding the mail box, can someone please guide on this.
Hi , One of my colleagues is getting this error message on his unity server while adding the mailbox on Unity .Can somebody guide on this issue.. unity ver.. 4.2
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
