03-01-2011 12:08 PM - edited 03-16-2019 03:42 AM
Greetings!
I have just bought an ATA 187 device and need to configure it for a fax line in my business with my CUCUM 7.1.5.30000-1 install. However, I don't have the ATA 187 device listed as an option when adding a new device... only the older ATA 186 version.
I've downloaded the following files:
cmterm-ata187.9-0-3-0.cop.sgn
cmterm-ata187-QED.cop.sgn
Unfortunately, I have no idea what to do with them. I attempted to upload them to the TFTP server and restarted it, but to no success.
How do I get the device added to my device list so that I can configure this device? I've looked through the release notes and they reference a readme file that I can't for the life of me find.
Solved! Go to Solution.
03-01-2011 12:21 PM
Hi there,
From the ReadMe (attached link below) You are on the right track, but use the method below instead;
For Cisco Unified Communication Manager Release 7.1.5, 8.0.2 and higher, you must do all software installations and upgrades by using the Software Upgrades menu options. The system can upload and process only software that Cisco Systems approved.
http://www.cisco.com/web/software/282074215/35161/cmterm-ata187.9-0-3-0-readme.html
Cheers!
Rob
03-01-2011 12:21 PM
Hi there,
Cheers!
Rob
03-01-2011 12:49 PM
Woohoo! Thank you!
I've uploaded firmware many times for phones, but it's my first ATA, and go figure I didn't realize that process for adding device packages.
04-05-2011 10:22 AM
Hi:
I followed the instructions found in the readme file. I have the Cisco 187 as an option and setup the ATA 187 in Call Manager
However, my ATA 187's won't register.
Here are the messages I'm seeing:
2000/01/01 00:11:04:516 Succeed to get XMLDefault.cnf.xml
2000/01/01 00:02:43:464 File Not Found : CTLSEP108CCFE0F4A2.tlv
2000/01/01 00:02:43:469 No CTL installed
2000/01/01 00:02:43:473 IP phone is in non-secure mode
MAC Address | 10:8C:CF:E0:F4:A2 | |
Phone 1 DN | 1050 | |
Status1 | Registering | |
Phone 2 DN | AUTO-REG | |
Status2 | Registering | |
App Load ID | APP187.9-0-3-1 | |
Boot Load ID | 1.8.0.6 | |
SW_Version ID | 187.9-0-3-1 | |
HW Reversion ID | Rev.06 | |
Serial Number | FCH1450B6P6 | |
Module Number | 550 | |
Product ID | ATA-187 | |
Message Waiting (Line 0) | Enable | |
Message Waiting (Line 1) | Enable | |
UDI | ||
ATA187 | ||
FCH1450B6P6 | ||
V01 | ||
Cisco Analog Telephony Adapter 187 | ||
Time | 12:17:22 AM | |
Time Zone | Mountain Standard/Daylight Time | |
Date | 01/01/00 |
DHCP Server | 172.16.2.1 | |
Host Name | ATA-187 | |
Domain Name | onetrack.net | |
DHCP Mode | Enable | |
DHCP Address Released | Disable | |
IP Address | 172.16.2.47 | |
Subnet Mask | 255.255.255.0 | |
Alternate Mode | Disable | |
TFTP Server 1 | 10.10.33.8 | |
TFTP Server 2 | 0.0.0.0 | |
Default Router 1 | 172.16.2.1 | |
DNS Server 1 | 205.171.3.65 | |
DNS Server 2 | 205.171.2.65 | |
DNS Server 3 | 0.0.0.0 | |
DNS Server 4 | 0.0.0.0 | |
DNS Server 5 | 0.0.0.0 | |
Call Manager 1 | 10.10.33.8 | |
Call Manager 2 | 10.10.32.8(Active) | |
Call Manager 3 | ||
Call Manager 4 | ||
Call Manager 5 | ||
Forwarding Delay | Disable | |
SW Port Setup Auto Negotiate | Enable | |
User Locale | English_United_States | |
User Locale Version | 7.1.0.1(3) | |
Network Locale | United_States | |
Network Locale Version | 7.1.0.1(3) | |
DSCP for Call Control | CS3 | |
DSCP for Configuration | CS3 | |
DSCP for Services | default | |
Security 1 Mode | Non Secure | |
Security 2 Mode | Unknown | |
Web Access | Enable | |
CDP: SW Port | Enable | |
Admin. VLAN ID | 4095 |
Thanks for everyone's help in advance.
03-01-2011 01:02 PM
Good stuff my friend
The Readme is only available when you click on the "Download Now" button
on Software Downloads. That's the only time you will see it.
Cheers!
Rob
