CUCM 7.1.5 - Help Installing ATA 187
muranskycotech
Greetings!
I have just bought an ATA 187 device and need to configure it for a fax line in my business with my CUCUM 7.1.5.30000-1 install. However, I don't have the ATA 187 device listed as an option when adding a new device... only the older ATA 186 version.
I've downloaded the following files:
cmterm-ata187.9-0-3-0.cop.sgn
cmterm-ata187-QED.cop.sgn
Unfortunately, I have no idea what to do with them. I attempted to upload them to the TFTP server and restarted it, but to no success.
How do I get the device added to my device list so that I can configure this device? I've looked through the release notes and they reference a readme file that I can't for the life of me find.
Rob Huffman
Hi there,
From the ReadMe (attached link below) You are on the right track, but use the method below instead;
Installing the  Device Enabler and firmware load
For Cisco Unified  Communication Manager Release 7.1.5, 8.0.2 and higher, you must do all software installations and upgrades by using the Software Upgrades menu options. The system can upload and process only  software that Cisco Systems approved.
  1. Using your      web browser, login to the Cisco Unified Operating System  Administration web page
  2. Under the Software      Upgrades menu, select Install/Upgrade.
  3. Fill in      the appropriate values in the Software Location section for  the      file you downloaded above, and click Next.
  4. In the Options/Upgrades drop-down box, select the file you downloaded above, and click Next.
  5. In the File  Checksum Details box, verify      you have selected the correct firmware and the MD5 has the correct  value,      click Next.
  6. Check that      you received a Success message.
http://www.cisco.com/web/software/282074215/35161/cmterm-ata187.9-0-3-0-readme.html
Cheers!
Rob
Rob Huffman
Hi there,
Cheers!
Rob
Woohoo! Thank you!
I've uploaded firmware many times for phones, but it's my first ATA, and go figure I didn't realize that process for adding device packages.
Hi:
I followed the instructions found in the readme file.  I have the Cisco 187 as an option and setup the ATA 187 in Call Manager
However, my ATA 187's won't register.
Here are the messages I'm seeing:
2000/01/01 00:11:04:516   Succeed to get XMLDefault.cnf.xml
2000/01/01 00:02:43:464   File Not Found : CTLSEP108CCFE0F4A2.tlv
2000/01/01 00:02:43:469   No CTL installed
2000/01/01 00:02:43:473   IP phone is in non-secure mode
MAC Address
10:8C:CF:E0:F4:A2
Phone 1 DN
1050
Status1
Registering
Phone 2 DN
AUTO-REG
Status2
Registering
App Load ID
APP187.9-0-3-1
Boot Load ID
1.8.0.6
SW_Version ID
187.9-0-3-1
HW Reversion ID
Rev.06
Serial Number
FCH1450B6P6
Module Number
550
Product ID
ATA-187
Message Waiting (Line 0)
Enable
Message Waiting (Line 1)
Enable
UDI
ATA187
FCH1450B6P6
V01
Cisco Analog Telephony Adapter 187
Time
12:17:22 AM
Time Zone
Mountain Standard/Daylight Time
Date
01/01/00
DHCP Server
172.16.2.1
MAC Address
10:8C:CF:E0:F4:A2
Host Name
ATA-187
Domain Name
onetrack.net
DHCP Mode
Enable
DHCP Address Released
Disable
IP Address
172.16.2.47
Subnet Mask
255.255.255.0
Alternate Mode
Disable
TFTP Server 1
10.10.33.8
TFTP Server 2
0.0.0.0
Default Router 1
172.16.2.1
DNS Server 1
205.171.3.65
DNS Server 2
205.171.2.65
DNS Server 3
0.0.0.0
DNS Server 4
0.0.0.0
DNS Server 5
0.0.0.0
Call Manager 1
10.10.33.8
Call Manager 2
10.10.32.8(Active)
Call Manager 3
Call Manager 4
Call Manager 5
Forwarding Delay
Disable
SW Port Setup Auto Negotiate
Enable
User Locale
English_United_States
User Locale Version
7.1.0.1(3)
Network Locale
United_States
Network Locale Version
7.1.0.1(3)
DSCP for Call Control
CS3
DSCP for Configuration
CS3
DSCP for Services
default
Security 1 Mode
Non Secure
Security 2 Mode
Unknown
Web Access
Enable
CDP: SW Port
Enable
Admin. VLAN ID
4095
Thanks for everyone's help in advance.
Rob Huffman
Good stuff my friend
The Readme is only available when you click on the "Download Now" button
on Software Downloads. That's the only time you will see it.
Cheers!
Rob
