01-28-2015 12:28 AM - edited 03-17-2019 01:45 AM
Is it possible in some way to force using "@" in the username field in SIP Realm?
My SP requires username in format "username@domain".
I don't have CUBE between me and SP.
Piotr
Solved! Go to Solution.
01-28-2015 02:38 AM
It was introduced in version 8.x as mentioned in the SRND
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/trunks.html#wp1124550
Regarding your first query, i am not aware of such a possibility.
Manish
01-28-2015 01:57 AM
Hi Piotr,
On CUCM you can only use alphanumeric characters, period, dash, underscore, and space for SIP Realm.
Manish
01-28-2015 02:15 AM
Thanks for you answer.
So it's not possible as for endpoint where you can force to set '+' by preceding it '/' ?
From which version of CUCM SIP normalization feature is available?
01-28-2015 02:38 AM
Manish
01-28-2015 02:46 AM
Manish,
It works for the DN configuration. I hoped that for SIP realm there is also some kind of a trick to force using special character. Anyway it seems that I need to do it on Acme SBC in sip-manipulation object.
Thanks for your answers
01-28-2015 02:59 AM
Yes, the '+' and '\' combination works for directory numbers and route patterns.
Manish
