[CUCM 7.1] SIP Realm username with @
piterrrek_p
Is it possible in some way to force using "@" in the username field in SIP Realm?
My SP requires username in format "username@domain".
I don't have CUBE between me and SP.
Piotr
It was introduced in version 8.x as mentioned in the SRND
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/trunks.html#wp1124550
Regarding your first query, i am not aware of such a possibility.
Manish
5 Replies 5
Manish Gogna
Hi Piotr,
On CUCM you can only use alphanumeric characters, period, dash, underscore, and space for SIP Realm.
Manish
Thanks for you answer.
So it's not possible as for endpoint where you can force to set '+' by preceding it '/' ?
From which version of CUCM SIP normalization feature is available?
Manish
Manish,
It works for the DN configuration. I hoped that for SIP realm there is also some kind of a trick to force using special character. Anyway it seems that I need to do it on Acme SBC in sip-manipulation object.
Thanks for your answers
Yes, the '+' and '\' combination works for directory numbers and route patterns.
Manish
