CUCM 8.0: don't get drop down manus
gavin han
I installed CUCM 8.0 successfully. Than logged on through web  interface and started all services. I'm running across one issue though.  after i logon to "CUCM Admin" and when i go to any of the manu then It  doesn't pull out drop down manu. i.e. if I hover to "Call Routing" then  it doesn't put out all options available under "Call Routing" manu.
please advise.
P.S.: I'm using VM workstation 6.5 and allocated 2GB RAM, 80 GB hard drive.
Jonathan Schulenberg
You can't use Chrome. Open the UI in Internet Explorer and the Javascript will work.
Thank you Jonathan. You are correct, chrome is not working ,  IE working.
Esa
Glad to hear it. Please be sure to rate successful replies and mark the thread answered.
