01-20-2015 01:54 AM - edited 03-17-2019 01:39 AM
we have a CUCM 8.5.1.14900-5 cluster.
We would like to add the support for Cisco 7821s, because currently we can't add a Cisco 7821 to the configuration.
We know that we can use this phone with our CUCM because the data sheet mentions CUCM 8.5.1 in the supported CUCM versions.
Furthermore, we know that, to enable the CUCM to "see" the 7821s, we have to install a Device Pack (or a QED file, if it exists) on all the nodes, but since we have installed some locale installers (cm-locale-xx_YY-8.5.1.1000-1.cop), we think that we have to install some newer locale installers to correctly localize the Cisco 7821s.
So, our questions are the following:
Thanks in advance for your help.
Best regards.
01-20-2015 02:16 AM
Please install the latest device pack for 8.5.1 ( devicepack8.5.1_17133-1 ) from the following link
https://software.cisco.com/download/release.html?mdfid=283423434&flowid=45897&softwareid=282074299&release=8.5%281.17133%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Read Me file which lists the firmware that will be installed for all phone types
http://www.cisco.com/web/software/282074299/119109/cmterm-devicepack8.5.1_17133-1_Release_Notes.pdf
Install it on all the cucm servers and then do a cluster reboot.
Manish
01-20-2015 02:56 AM
Hello Manish,
so, no QED file exists for Cisco 7821s? :-(
I'm asking you that because meanwhile I've found the following bug, but I can't unterstand it:
https://tools.cisco.com/bugsearch/bug/CSCui87247/
It tells about "Qed and support files for 7821/7841/7861 Phones" and its status is "Fixed", but I can't find any QED file on Cisco download site...
Regards.
01-20-2015 02:29 AM
Manish has covered the Device Pack. About the locales, you will need to install Phone only installer. You can install the device pack, locale installer and then reboot the nodes (you dont have to reboot twice)
The latest version supported with 8.5 is
Release 10.2(2 ) Refer to Read me: http://www.cisco.com/web/software/282074291/117120/po-locale-10.2.2.1000_ReadMe.pdf However there is a similar thread going around with some users having issues installing this locale, with locale complaining about major.minor number not matching. Refer to the thread here: https://supportforums.cisco.com/discussion/12322136/locale-7821-cucm-85110000-26 (its not resolved) -Terry Please rate all helpful posts |
01-20-2015 03:00 AM
Hello Terry,
OK, I'll try to investigate about that issue with locale installers, to see if our CUCM version is affected, too.
Thanks and regards.
01-23-2015 07:50 AM
Hello Terry,
I have successfully installed the device pack and the locale installers on our CUCM, so the version 8.5.1.14900-5 shouldn't be affected by that bug.
Regards.
