02-09-2011 01:07 AM - edited 03-16-2019 03:21 AM
I have a quick question: is VG224 compatible with CUCM 8.5(1)?
Thanks in advance and regards.
Solved! Go to Solution.
02-09-2011 02:47 AM
According to the following URL, VG225 running
15.1(3)T is compatible with CUCM 8.5.1
You should go at the end of the page.
Pierre.
02-09-2011 02:47 AM
Pierre.
02-09-2011 03:28 AM
Dear Pierre,
thank you for your answer.
I had found that page, but it's not clear why there is a "hole" in a cell above.
If you search "Cisco VG202 and 204 (analog voice gateway)" in the web page, in fact, there are 2 rows: one not populated in the column "Release 8.5(1)", and below one populated...
So my question to be sure of the compatibility.
Regards.
02-09-2011 05:56 AM
Hi Raziel,
Pierre is most correct here (+5 Pierre!)
Here are the 8.5(1) test results, you can see all the "passed" tests for
the VG - series (202/204/224/248)
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC8.5.1/ipt_test_results/tript851.pdf
Cheers!
Rob
