CUCM 8.5 license issues
divine007
 is this: we have a VOIP architechture with CUCM 8.5 with 100 telephones that operate their model is: 7942,7962,7975.
We have 135 additional posts that we want to integrate our solution. These phones have the model
DX650-K9 (5)
7821-K9 (50)
7906G (50)
7975G (10)
7962G (20)
To integrate this solution we buy licenses:
CIS-BES6K UCL-NETHERLANDS (135)
CIS-CON-SESV-UCMUCBAS SWSS SC (135)
Here is our need for support
1- What is the real model of licenses we need to add these new phones?
2- Can we change the licenses we bought for with versions compatible with our CUCM 8.5?
21 Replies 21
Aman Soi
for 7821 ----Basic UCL
DX650--- enhanced UCL
7900 series ---Enhanced UCL
I suppose u would have bought DLUs .If that is the case, u can register these IP phones with CUCM 8.5  as well.
I got this reference BE6K-UCL-BAS
and CON-SNT-CP7821K9
as to what i wish to install
But am abit confuse if it will work with the cucm 8.5
Hi Ambe,
the part code which u have mentioned is for BE6000.
You need to select CUCM-USR-LIC-ADD for adding user licenses and LIC-CUCM-BASIC-A for Basic users / LIC-CUCM-USR-A for enhanced users [users less than 1000]
You can also get in touch with Cisco SE/AM for more clarity.
regds,
aman
ok thanks alot
i got the license and uploaded
but when i which to add a CP i don't see it
any advice
any advice
Hi ,
what is the endpoint u are trying to add  and what is your exact CUCM version?
Are u not able to see endpoint while adding ?
regds,
aman
Am trying to add 7821 for instance when i go to Device=phone=add new i don't see the type in the list. support give me a tempo license for 12months. see license already added in attached file. after uploading the licenses the device was restarted
The version for my cucm is
admin:show version active
Active Master Version: 8.5.1.10000-26
Active Version Installed Software Options:
Suggest u to upload device pack on one of the server and reboot it.
Before u uplaod Device pack, make a note of existing firmwares /take snapshot under Device ---Device settings---Device defaults so as to avoid upgradation for other IP phone models.
After u upload device pack, check again for device sdefaults and revert the firmware back to original ones and Save it.Now reboot server.
https://software.cisco.com/download/release.html?i=!y&mdfid=283423434&softwareid=282074299&release=8.5(1.18135)&os=
regds,
aman
OK great and that's it the file piece
My last question is the uploading
Am using win 7 for the upload any particular way of doing this?
you can refer the  below procedure which is mentioned in relese notes for uploading device pack
http://www.cisco.com/web/software/282074299/121307/cmterm-devicepack8.5.1_18135-1_ReleaseNotes.pdf
Step 1 Using your web browser, log in to the Cisco Unified Communications Operating System Administration web page.
Step 2 From the Software Upgrades menu, select Install/Upgrade.
Step 3 Fill in the appropriate values in the Software Location section and click Next.
Step 4 In the Available Software drop-down box, select the device package file and click Next.
Step 5 Verify that the MD5 has the correct value. Click Next.
Step 6 In the Warning box, verify that you selected the correct firmware and click Install.
Step 7 Check that you received a Success message.
Note Skip to Step 9 if rebooting the cluster
Step 8 Stop and restart the TFTP server.
Step 9 Reset the affected devices to upgrade the devices to the new load.
regds,
aman
you can get the MD5 when u keep mouse on Device pack.
I have attached snapshot.
regds,
aman
You are awesom
thanks
hey,
Can you tell me if 7821 and DX650 register using sip or sccp in cucm 8.5
i see just sip inside
