10-07-2013 09:39 AM - edited 03-18-2019 11:18 AM
The Issue i am having is that my CUCM Pub. cannot communicate with our NTP server due to our NTP server requires a trusted key. Is there a way to input this key in CUCM so that it can pull the appropriate time?
10-07-2013 09:50 AM
What are you using as your NTP source?
Best source is a Cisco network equipment such as a router.
HTH,
Chris
10-07-2013 09:54 AM
It is using a router as it's NTP source, but it requires a trusted key be used and i do not know how to input the key in CUCM.
10-07-2013 09:55 AM
Why does it need a trusted key for NTP?
Chris
10-07-2013 09:58 AM
It is a security requirement for where I work. That is why it is frustrating to me, why for ntp.
10-07-2013 01:32 PM
can you use the below command to show the logs , please?.The below command can be done by SSH to your CUCM IP address.
utils network capture port 123
Thank you
please rate all useful information
