08-02-2011 10:38 PM - edited 03-16-2019 06:16 AM
Hi Guys,
I have a CUCM 8.5 cluster.
I didnt configure an Internal Partition for the internal DNs , just Partitions for the Route Patterns , so people can call to everyone and outside to the PSTN ; this configuration is working fine.
The issue that I have is with the "Batphone" configuration , I searched and found severals documents , I did every step the documents say , but the call do not go through , I lift the handset , and the phone just give dialtone.
I created the Blank Translation pattern with a partition for this purpose , left the CSS to NONE , so the TP can call the phone and configured the corresponding DN number on the Called transformation mask.
I am thinking , the problem is the lack of an internal partition.
Does anyone know if this PLAR configuration can be done on a system without internal partition?
Thanks for any help
Joel
08-03-2011 12:54 AM
I don't think you can - this setup relies on the translation pattern being the only match when the handset is lifted; whereas on your system anything in
It's considered bad practice to use the
I think your best option would be to do this:
1) Create a new 'Internal' partition.
2) Add the 'Internal' partition to the bottom of every CSS
3) Run a BAT job to update all lines in the
You would also then need to check for any devices that don't have CSSs at all (these would need an 'internal-only' type CSS adding).
Aaron
Please rate helpful posts...
08-03-2011 01:36 AM
Hi.
You can try as follow.
Create a partition for "Bat Phone" es. BAT_Partition
Create a CSS (es. Bat_CSS) and include BAT_Partition only
Create a blank translation pattern , put it in BAT_Partition and select Bat_CSS and insert your destination DN in Called party transformation mask.
Associate the css BAT_CSS to the DN you want to activate the BAT Phone funcionality.
Carlo
08-03-2011 02:31 AM
Hi again.
Just an explanation of my suggestion..
The CUCM, to perform a destination match, looks into partitions listed in the CSS associated with the Phone DN which dials a seuence of digits, and it selects partitions in a Top/Down Manner....
Because the Null Partition is located at the end of partition list in a CSS, CUCM search first in BAT_Partition of my previous example, finds a blank destination and starts to setup the call immediately.
Hope this Help
Carlo
08-03-2011 02:38 AM
i think calro assumption is right you can try it and confirm
08-03-2011 02:52 AM
No harm in trying :-)
However - digit matching is based on longest match in CCM.
Partition order is used as a tie-breaker where two equal matches exist.
So theoretically partition order won't have any effect as the matches are not equal.
Aaron
08-03-2011 03:00 AM
Yes Aaron.
You're absolutely right.
Carlo
08-03-2011 08:13 AM
Hi Guys, thanks for all your help.
I did several tests , and the only time it worked , was when I enabled the Auto Registration and then configured the
Thanks for the help
Joel
