06-21-2012 12:25 AM - edited 03-16-2019 11:46 AM
I want to match this translation pattern 9[3-9].! and transform it to +00[3-9].!
Is it possible to do such translation in one translation pattern?
example1:
called number is this: 9312345
Translated number should be: +00312345
example2:
called number is this: 94111
Translated number should be: +004111
example3:
called number is this: 9722222222
Translated number should be: +00722222222
Thanks.
Raymond
Solved! Go to Solution.
06-21-2012 12:44 AM
Hi Raymond
Yes, you can do this/:
Pattern: 9.[3-9].!
Called Party Transforms:
Discard Digit Instruction: Predot
Prefix \+00
Obviously assigning an appropriate partition and CSS to the translation as well...
Principal Engineer at Logicalis UK
Please rate helpful posts...
06-21-2012 12:44 AM
Hi Raymond
Pattern: 9.[3-9].!
Prefix \+00
06-21-2012 01:12 AM
Hi Aaron Harrison,
Yes, It works.
Thank you.
Raymond
