01-10-2013 12:38 AM - edited 03-16-2019 03:05 PM
I've a cisco cucm 8.6.2 and I'm triyng to configure a call pickup group.
I've configured the call pickup group and I've createde a phone button template with the softkey pickupgrp and I0ve accioate it to all ip phonees.
All its ok with the ip communicator and cisco 7940/60 phones, but when I'm configure the callpickp gruop under the 6945 phone the cucm return this error message:
update failed. This device has restricted value on maximum call, input value is not valid
the device is oconfigured with maximum numerb of calls 4
and busy trigger 1
can you have any suggestions?
thamks
giancarlo
01-12-2013 12:54 AM
Change the busy trigger to 2
01-12-2013 09:02 AM
If you are unable to change it as it is hard coded on the phone, you will need to upgrade the phone firmware to later release.
Chris
