10-24-2012 12:30 AM - edited 03-16-2019 01:51 PM
10-24-2012 12:39 AM
Check that one
10-24-2012 12:40 AM
HI,
For CUCM 9.0 release notes on the upgrade procedure refer the below link,
Hope this helps.
Anand
Please rate helpful posts !!
10-24-2012 01:00 AM
Hi Anand,
I went thrugh the release guide for UC 9.0 in that it does not mention clearly about which UPGRADE file should be used however you mean to say that the first link which points to COP.SGN file is the exact same file to be used for upgrade form 8.6 to 9.0
10-24-2012 01:19 AM
No, this COP file (ciscocm.refresh_upgrade_v1.0.cop.sgn) is defferent than the upgrade file.
Caution | For both restricted and unrestricted upgrades from an 8.5(x) or earlier release to a 9.0 release, this patch (COP file) must be applied prior to initiating the upgrade. Before you upgrade from compatible versions of Unified CM, install the COP file named ciscocm.refresh_upgrade_v1.0.cop.sgn that you can find under Cisco Unified Communications Manager Version 9.0 > Unified Communications Manager / CallManager / Cisco Unity Connection Utilities > COP-Files. |
Service Updates (SUs), contain fixes that were unavailable at the time of the original release. They often include security fixes, firmware updates, or software fixes that could improve operation.
To check for software upgrades, Service Updates, critical patches, from www.Cisco.com:
To upgrade to Unified CM Release 8.6(2a) from a release prior to 8.0(1), use the Product Upgrade Tool (PUT) to obtain a media kit and license or purchase the upgrade from Cisco Sales.
To use the PUT, you must enter your Cisco contract number (Smartnet, SASU or ESW) and request the DVD/DVD set. If you do not have a contract for Unified CM, you must purchase the upgrade from Cisco Sales.
For more information about supported Unified CM upgrades, see the Cisco Unified Communications Manager Software Compatibility Matrix at the following URL:
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/compat/ccmcompmatr.htmlhttp://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
See the "Software Upgrades" chapter of the Upgrade Guide for Cisco Unified Communications Manager, Release 9.0(1).
Hope this helps.
Anand
10-24-2012 02:08 AM
Hi Anand,
Thank you for your quick reply,so in order to get Upgrade file i need to contact with cisco Cisco Sales guy
10-24-2012 02:53 AM
HI,
Yes, thats right.
Please don't forget to rate the helpful posts.
Anand
