04-08-2011 06:01 AM - edited 03-16-2019 04:25 AM
We are running a CUCM 8 cluster and have a cisco 2811 that is taking care of sip trunk connectivity for PSTN access.
The 2811 is also our MTP,CFB and Xcoder.
Whenever we put an inbound or outbound PSTN call on hold, there is silence. Internal calls have no issues with MOH.
Any idea what I'm doing wrong?
Jeroen
Solved! Go to Solution.
04-08-2011 11:19 AM
If that did correct it, it's pretty obvious a MTP is in use. I will have to research to find the bug ID if you are indeed hitting this.But I remember that the the fix was actually a downgrade of the gw IOS.
04-08-2011 06:06 AM
Do you have media resources assigned to the SIP trunk? (MOH mainly)
HTH,
Nick
04-08-2011 06:11 AM
Thanks for your reply. I have the same MRGL assigned to the sip trunk as I have assigned to my phones.
Both cucm moh resources are part of the MRG.
Rgds,
Jeroen
04-08-2011 06:56 AM
Hey,
Are you using unicast or multicast?
What exactly happens when you place a call on hold? Do you hear a tone?
Nick
04-08-2011 06:57 AM
Hi Nick,
I'm using unicast. When I place a call on hold, it is just silence, no tone.
Rgds,
Jeroen
04-08-2011 07:04 AM
Try checking the MTP checkbox on the SIP trunk page.
04-08-2011 07:07 AM
Hi Nicolas,
MTP is allready checked.
Jeroen
04-08-2011 07:03 AM
Are you by any chance using the g.729 codec?
Have you enabled all the codecs in the service parameters-> ipvms-> all moh codecs?
04-08-2011 07:12 AM
Hi Payal,
Only 711ulaw was selected. I have now selected all codecs and restarted the IPVM services on both nodes.
still the same issue.
Rgds,
Jeroen
04-08-2011 07:18 AM
I guess yo are resetting the trunk (just making sure )
Try adding the following in the VG: "ccm-manager music-on-hold"
04-08-2011 07:24 AM
Hi Nicolas,
Did not reset the trunk yet after the change. Have done it just now and the issue persists.
I have also added the command "ccm-manager music-on-hold" on the gateway, same issue still.
Rgds,
jeroen
04-08-2011 10:40 AM
What version are you running on 2811?
Is the 2811 acting as a SIP to SIP CUBE? If so, do you have 'mid-call signaling passthru' configured?
Or if it is H323 to SIP CUBE, is emptycapability configured?
Do you see the output of 'sh call active voice brief' change to the IP of CUCM when the call is put on hold?
Have you collected a debug off the router during the issue?
04-08-2011 10:44 AM
Hi Steven,
I'm running 151-3.T
The 2811 is acting as a SIP-SIP Cube
I do have the 'mid-call signaling passthru' configured.
When I put a call on hold, the IP address changes to IP 0.0.0.0:0
Jeroen
04-08-2011 10:59 AM
I believe you may be hitting a bug...What type of MTP's are you using in the MRG? Are they hardware or IOS sw? If so could you try using CUCM SW MTP and see if that works.
TY
04-08-2011 11:01 AM
I'm using hardware MTP's. I'll give the software MTP's a try and report back.
Can you share the bug ID?
Rgds,
Jeroen
