02-08-2011 07:42 AM - edited 03-16-2019 03:19 AM
Folks,
I'm working on a IP Telephony new implementation project. CUCM 8.3 is going to be installed on a Brand new UCS C series server as a Publisher. The existing three MCS 7845 servers are going to be configured as subscribers. I 'm looking for some document which gives the procedure of 8.x installation on a MCS 7845 server with VM Ware environment. Thanks in advance.
Ashraf
02-08-2011 12:06 PM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
Install on MCS is exactly the same as with any previous versions.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-08-2011 12:39 PM
I like the easy-to-remember url: cisco.com/go/uc-virtualized
(redirects to http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization)
