CUCM 8.x installation on MCS 7845 Server
ashrafkhanm
Folks,
I'm working on a IP Telephony new implementation project. CUCM 8.3 is going to be installed on a Brand new UCS C series server as a Publisher. The existing three MCS 7845 servers are going to be configured as subscribers. I 'm looking for some document which gives the procedure of 8.x installation on a MCS 7845 server with VM Ware environment. Thanks in advance.
Ashraf
Jaime Valencia
Installing Cisco Unified Communications Manager  on Virtualized Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
Install on MCS is exactly the same as with any previous versions.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I like the easy-to-remember url: cisco.com/go/uc-virtualized
(redirects to http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization)
